1 - 12 of 12 Posts
I am stuck at 3.6 stable at 3.7 its unstable i get like memory dump or something like that when trying to to boot into windows I really want to hit 4.0GHz. A lot of info on my pc is in my sig rig if you need anymore info LMK!
i had a e8400 i think it was a co stepping, i only was able to get 3.8ghz with 1.36v. could be your memory holding you back, i like corsair good memory try pc2 1066. but try a loser timming and more voltage.
you might need to get a e0 stepping.
Originally Posted by ericeod
What are your voltages, ram settings, ram divider and FSB speeds (are you using the 9x multi)? Any CPU-Z screenshots of the CPU and memory tabs?
Well volts for my cpu is 1.3 my ram volts is 2.0 with timing in my sig rig multiplier is 9x I'll get pics tomorrow im currently not at my pc atm,
Up the CPU voltage to 1.36, and make sure thats what it is after vdroop. My e8400 (C0) does 4.1 on 1.35, but I havent even tried to go lower, I just set it to there and away I went.
I also unlinked my ram, so it would stay at its stock speed. If you unlink, no need to consider memory as a hold-back.
Drop your multiplier and set your FSB to 1800 (450) then keep your multi at 7 or 8 and stress test
if that fails, its not your CPU, its your motherboard or RAM.
if that passes, bump up multi and test using different GTLLref volts or FSB volts (Not NB, FSB, different stuff)
Discussion Starter · #8 ·
were do I go in BIOS to unlink it?
No idea.. never used that board before... chances are it will be somewhere in the section that configures your cpu(speeds/multi), or memory (speeds/timings)
You cant unlink ram on Intel chipsets. That is only on NVIDIA. All the OP can do is set the memory divider to the lowest (1:1) to clock the ram at it's lowest possible clock.
And OP, you have to add NB voltage as you increase the FSB speed. I am guessing your problem is down to two things;
1. Your ram is running out of spec since you have increased the FSB but have not chnaged the divinder.
2. The NB voltage needs to be at least 1.35v to try and run a 400 FSB OC.
Also note that there is an OCN thread on OCing this board:
http://www.overclock.net/intel-mothe...on-thread.html
Here is a thread at XtremeSystems on this board:
http://images.google.com/imgres?imgu...%3D1%26hl%3Den
Intel Overclocker
I have CO and was able to 4.0 even I didn't like the voltage that high. Dropped it back to 3.91 @ 1.3v
Lol C0 stepping was good, its the C1 and up that suck.
Like I said before, use a low muliplier and raise your FSB and work on getting that stable, even if it is 2.6ghz, if you got the 450FSB stable you are highly likely to get your 4ghz stable afterward
1 - 12 of 12 Posts
