1 - 11 of 11 Posts
Hi guys i know i asked this before but i didnt much response. I'm looking for a mid- high end earphones thats great for music and gaming. I currently use the Shure e2c earphones but unfortunately one side is gone. I'm looking for some sort of noise cancelling with good bass and i'll be able to hear where the enemies are coming from. no more than $150 please
thank you
Audio Technica M50, Audio Technica ATH-Pro700MK2, or Ultrasone HFI-780.
Edit: Oops, earphones only. Gimme a sec..
Originally Posted by rafiki121 View Post
Sorry if i didn't make it clear. I want earphones only. I cant stand having large headphones
Ahh sorry, Panasonic RP-HJE900 or Monster Turbine Pro Gold should work well
Discussion Starter #6
Thx for the quick suggestions. Once again i'm sorry but can you give me suggestions anywhere below 150
What is your budget?
Edit: Hahaha OP you keep on ninja'ing me...
Hippo VB or DUNU Hephaes (very bass heavy and a cheap amp is recommended)
Might want to check out something from Audeo's PFE series.
Discussion Starter #11
Thx for all the reply. Question will you guys pick the NuForce NE-700X or the Phonak Audéo PFE 012 Perfect Bass thank you
1 - 11 of 11 Posts
