ECS 650i-any good?
521 Views 10 Replies 8 Participants Last post by  a300
Yes-I did search, but nothing was of any use. I accidentally ordered a p45 MoBo and I need SLi support. The heatsinks on the 650i are painfully tiny and that fan-ugh! Looks like cheap, noisy stuff.
LINK:
http://www.newegg.com/Product/Produc...2E16813135047R
I don't care much for extreme overclocking. Does the fan come stuck on the board as default or as an accessory? I don't want to get the board without a fan.
Does it support 2 9600GTs in SLi?
and-yes I know it's x8.
Also, if you have it, please give me your opinion. Links to reviews are greatly appreciated.
-Thanks
1 - 11 of 11 Posts
Nah I wouldn't buy it. That board is pretty poor at best.
itll work i have a 650i BUT its about the worst 775 sli mobo with core 2 support you will find. I suggest looking into an open box 750i, my brother got one for $67.50 from newegg, asus p5n-d, way nicer than a ecs 650i too. and its pci-e 2.0 x8 aka pci-e 1.1 x16 bandwidth so its a much better board, just look for some open box ones, its worth waiting for one to pop up, be patient.
It's ECS and like anything ECS is guaranteed to die in about 2 months. Just to give you a idea of how bad ECS, they use ECS in E-Machines.
lol nuff said.
Yeah...ECS is not really designed to overclock...heck it's hardly even designed to last longer than a couple of months. I would avoid the ECS brand name altogether if you can.
Like sgdude suggested just wait until the a P5N-D pops out. Not only does ECS have bad rep but the 650i chipset is outdated. Don't get me wrong I liked my 650i Asus, but you should wait and get something better.
Originally Posted by sgdude View Post
lol nuff said.
I have an ECS Socket 754 board still in service, for many years now, overclocked.
same.
nF3 on mine.
I have 3 and none have failed me yet.
As for the ASUS... isn't that the one with the broken fan problem
I have a ECS S939 that i have used for 3 years now and still going strong and as far as OC goes i it did 3.0Ghz on 3700+.
1 - 11 of 11 Posts
