Here is an update...
I FINALLY got Windows loaded and everything is rock solid. I tried everything including different HDs, PSUs, CD ROMs, etc. I finally took everything out of the case and tried it that way. The only thing I did NOT connect that I had connected before was the mouse and Patch cable into the second NIC.
I don't think it was the mouse as I think I tried to load Windows without it prior to this and it still locked up. So, as odd as it may sound, it looks like it was the patch cable. Now after I got Windows loaded, I installed the driver for the nVidia NIC, updated the one for the other, and set all my IP settings and plugged the patch cable into the nVidia one (i won't be using the second one for now). Like I said above, all is rock solid.
Just to comment on the stock cooler for the 7800 GT and the Zalman 9500, CRAP THESE THINGS ARE LOUD. I definately need a new video cooler and I might look into getting the Big Typhoon.
