1 - 3 of 3 Posts
looking for anymod either for the bios for this board i have unlock alot of extra features using the ctrl f1 but there is still no change to boost the volts<br />
does anyone have any suggestions to mod the bios or either the cpu itself
Administrator
Well that motherboard is not the best of brands. Most motherboards will only allow a certain amount of V-core to be applied. This is normal..However for a new BIOS for this motherboard check here ;<a href="http://www.ecs.com.tw/ECSWeb/Downloads/Category_Download.aspx?Categoryid=1&MenuID=35&LanID=9" target="_blank">http://www.ecs.com.tw/ECSWeb/Downloa...uID=35&LanID=9</a>
Thank you i have all ready checked there and have updated to the most current bios available i have also used the hidden ctrl f1 to unhide some features is there any mod to raise the volts right now it is locked at 1.35
1 - 3 of 3 Posts
