Originally Posted by Ste Do you have an LDT voltage on the board? If so, crank that up a bit as that's for the IMC, so might help. Also, have you gone in and tweeked all the smaller timings in the bios for the memory? Some of these can have a real impact on stability. If you haven't, I'd recommend doing this first. |
Originally Posted by StillmaticX Ok, I really don't consider myself a noob as far as overclocking is concerned but I am certainly not an expert so I have to admit I'm not sure what you mean by the LDT voltage and IMC. I've tweaked everything from the timings, to v-dimm, etc, and I still can't get my system stable. I've run memtest a million times, testing each new setting. Can you please clearify what you mean? Thanks man. |
Originally Posted by Mastacator I don't think the Asus board has those settings for Chipset, and IMC voltage control. At least my A8N-SLI Deluxe doesn't. I imagine the premium doesn't as well, same bios and all. This board just doesn't overclock well above 240. I can't get it stable above 240 either. Whats your CPU voltage at though? |
Originally Posted by tweako_420 Dont spread lies. My board clocks up to 340mhz. So you are doing something WRONG. There is the option for LDT and IMC voltage but its named differnetly. HTT voltage (chipset) tho it only goes to 1.65 i think and another one i forget the name and too lazy to get into the bios but its right beside it. |
Originally Posted by StillmaticX I know that some people have had good experiences with Patriot XBLK ddr600 memory, but I have had nothing but problems with this memory since I first got my first gig (512 x 2). First of all, I can't get my comp stable wit 300mhz fsb even with the multi down to like 8. Furthermore, when sporting like 2 gigs (512 x 4), I can barely get my comp stable above 250 and at times 240. This is trash for memory which is like $200 a gig and should be providing be with a ridiculous amount of overhead. Anyway, I'm thinking about junking this memory and by "junking", I mean selling the <expletives> on ebay for whatever I can get. The question I pose to you all then is: What is the best memory out there for reaching like 300 fsb or what memory do you guys recommend for this? The mem doesn't have to be ddr600 but the higher ddr, the more overhead, OBVIOUSLY!! ![]() |
