1 - 7 of 7 Posts
I've just discovered that the Extreme editions of intel Cpu's have their multiplier unlocked.<br />
Thas that mean overclocking till friing?<br />
What are the limits that make you need to stop overclocking ( temp, vcore?<br />
And also , post your EE overclocks
Discussion Starter #2
bumping
Im running a X6800 EE Frying is not that simple. You have to watch your volts and heat the 2 big factors in killing a CPU the fact that the EE & ES addition CPU's are unlocked has no effect on frying ones CPU its the PPL that push there CPS beyond ther limits, with proper cooling you can get more outta it without having to subject it to the heat but you still have to contend with the Volts another killer also volts = heat so be wise and back it down once you find the top mark!!!<br />
<br />
The highest I ever had a CPU was 4.8 a D960 on water.
Screen shot temps volts under a modreate load full load temps go 47c volts 1.4<br />
<br />
had old screen up below post newer one sorry<br><a href="http://assets.overclock.net.s3.amazonaws.com/7/7f/7fc0cee1_vbattach33391.jpeg"><img src="http://www.overclock.net/image/id/616932/width/525/height/525/flags/LL"></a>
Newer shot @3800<br />
<br />
<a href="http://www.overclock.net/attachment.php?s=d51c1a11b1f7d586c94ba64097780a71&attachmentid=33392" target="_blank" title="">Attachment 33392</a><br><a href="http://assets.overclock.net.s3.amazonaws.com/e/ed/ed288566_vbattach33392.jpeg"><img src="http://www.overclock.net/image/id/616931/width/525/height/525/flags/LL"></a>
Nice temps <img src="/images/smilies/redface.gif" border="0" alt="" title="Embarrassment" class="inlineimg" />
Discussion Starter #7
COol overclock.Nice temperature , your using stock fan?<br>
ANy other EE overclocks?
1 - 7 of 7 Posts
