1 - 1 of 1 Posts
Discussion Starter · #1 · (Edited)
Trapper Ainsworth - YouTube - eGlobal AMD Ryzen 5 3550H MINI PC Videos
EGLOBAL Newest ultra Mini PC 12nm AMD Ryzen5 3550H dual 4K low cost mini computer (eglobaltech.cn)
2519145
New Cinebench R15 results after using Delta 70mm 5,500rpm 55cfm fan on the back of the core PCB & front on top of the VRM.
2518637
2518640
2518641
2518639
2518638
Memory Timings Overclocked RAM
2518635
2518634
You can fit a 15mm thick drive in this PC as well. I installed a 4TB drive in there no problem except you have to push the screws in a little harder to get them to catch & theres a slight bowing in the panel but it's not a big deal.
2500U HP ENVY x360 15" vs eGlobal AMD Ryzen 5 3550H
2518582
Tomb Raider 2013 benchmark 1080p low this time at 48W 96A 84°C
2518587
Tomb Raider 2013 benchmark 1440p & 4k 2160p low preset @ 75w 150a 110°C
2518585
2518586
2518575
2518576
2518577
2518578
2518444
2518445
2518446
2518447
2518448
2518450
Windows 11 is faster than Windows 10 on this PC by 1.5 FPS average @ 1080p
DDR4-2733 Overclocked & Timings @ 15-14-15-14-28-48-1T
720p lowest preset Rise Of The Tomb Raider High Performance Power Plan
2518572
1080p lowest preset Rise Of The Tomb Raider Balanced Power Plan
2518573
1080p lowest preset Rise Of The Tomb Raider High Performance Power Plan
2518574
1 - 1 of 1 Posts
