1 - 17 of 17 Posts
I recently bought used parts(not recieved yet).
What makes me worried is I recently found out that EK had a smaller fiasco during 2011 juny with CPU blocks using nickel?
The CPU block I'm soon getting is named EK Water Blocks EK-Supreme HF - EN (Nickel).
http://www.aquatuning.de/product_info.php/info/p8633_EK-Water-Blocks-EK-Supreme-HF---EN--Nickel---775-1156-1155-1366-2011-AM2-AM3-939-XEON-.html
So now I'm worried the nickel/copper will corrode/fall off
Maybe adding anti corrosive every 6 months avoids this problem?
As I understand the quality of the EK might be not perfect.
Using an anti-corrosive is a good idea especially given the recent events regarding nickel failures. The EN plating is supposed to fix the issues as they've stated. Use an anti-corrosive and don't worry about it imo, you've done what you can. If it becomes an issue, you can easily strip the nickel or just rma the block.
Seems like the EN is improved.
So even if the Nickel is corroding I can just strip it off the nickel so the copper is bare?
I don't think RMA is possible as I'm not the original buyer,
Aww crap, that's the block that I just bought not too long ago. I hope I won't run into the same issue when I get my rig up and running. Maybe I should take my own precautions and strip the nickel now, before it's too late.
Discussion Starter · #6 ·
You also have the EN version?
The EN version is supposed to be the new version which does not have the problem.
Incase the nickel does corrode into loop is that dangerous?
LOL NO, don't do that. Just use anti-corrosive agent, inhibitors and forget about the issue. IF it becomes an issue later will be a year from now, then you tackle it then.
Discussion Starter · #8 ·
Can I buy some anti corrosive from car shop?
A watercooling shop had only one bottle and it was anti corrosive for 2.5l of destilled water and the shipping is wery expensive
Thanks for the advice. Much appreciated.
Discussion Starter · #11 ·
I would only use something non-toxic, however I'm sure you could order something from Aquatuning since they cater to the euro market,
Why does it have to be non-toxic?
I Am Gooble Gobble
would you like to inhale fumes? toxic stuff also makes plasticizer bleed in our piping if im not mistaken.
Old to Overclock.net
What Sarge said, you know it's like poisonous. And it's illegal to dispose of it in your sink, yard, etc.... hazardous materials. It's a lot easier/safer using pc coolant.
Actually in most cases, for the quantities in question (small) and the context (individual household use) it may not be environmentally responsible to dispose of "everyday" hazardous materials in the regular trash or sewers, but it's very unlikely to be illegal.
FWIW, I'm a bit of a toxic phobic myself, but not all corrosion blockers are EG based.
EK's new coolant is one of those that are the non toxic variety. Near as I can tell, about the only harm it could do is irritate your eyes. Here is thier MSDS sheet:
http://www.ekwaterblocks.com/shop/EK-PSS/EK-PSS-3830046999634.pdf
It appears to have similar properties as this common food grade antifreeze where low toxicity is not only critical but required:
http://www.accepta.com/details.asp?cat=100&scat=50&id=8700
1 - 17 of 17 Posts
