1 - 16 of 16 Posts
EK releases new XRES liquid cooling pump reservoir combo!
EK Water Blocks, Slovenia based premium liquid cooling gear manufacturer, is proud to introduce EK-SPC Series of pump reservoir combo units. Recently debuted with Slim Series kits, EK-XRES 100 SPC-60 MX PWM with included pump is now available as a standalone product!
EK-XRES 100 SPC-60 MX PWM (incl. pump) is a value oriented water cooling pump reservoir combo. It has been designed to lower the production costs yet still offer great hydraulic performance at the best price.
Excellent choice for mini ITX builds!
The core of the unit is EK-SPC 60 water pump that uses only a 4-pin PWM FAN header for operation; no MOLEX connector is required! PWM control will allow you to set automatic pump speed regulation depending on your CPU temperature. Full performance on demand or whisper quiet operation in idle mode!
With the maximum pressure head at 3.2m (10,5 ft), maximum flow at 450 L/h and a very compact form, we recommend this pump reservoir combo for smaller builds, particularly if you are assembling your custom loop in a mini ITX case.
Very compact form factor makes this pump reservoir combo a great choice for mini ITX builds!
EK-XRES 100 SPC-60 MX PWM series reservoir comes preinstalled with anti-cyclone insert for preventing any vortex issues. The main body features two G1/4 threaded ports, of which one is an inlet (in the reservoir) and one is an outlet (from the pump). At the bottom of the unit, customers will find vibration dampening rubber mounting system which effectively de-couples the water pump from the rest of the computer chassis. Reservoir tube is made of quality acrylic material, while the rest of the pump/reservoir body is made from injection molded quality ABS material.
XRES SPC MX reservoir can be easily upgraded with longer reservoir cylinder tubes, used by EK-RES X3 series reservoirs.
Availability and pricing
EK-XRES 100 SPC-60 MX PWM (incl. pump) is already available for purchase through EK Webshop and Partner Reseller Network. Below you can find MSR prices with VAT included.
  • EK-XRES 100 SPC-60 MX PWM (incl. pump) 75.95€
Missing friends
can we get a few perspective shots, maybe a HD or SDD or can of coke next to it ?
WaterCooler
I see the holes in the bottom are still 50x50mm. Can other tops be used too? Also will this pump be sold separately?
It's the same size as EK-XRES 100 MX DDC 3.2 PWM unit. But good idea about the scale nonetheless
1) No, they can't.
2) Yes it will, with XTOP type volute. ETA few weeks.
Missing friends
then ill buy that, i <3 ddcs !
WaterCooler
Last question than I'll shut up
Is this the same pump that is currently in the Predator AIO series?
Missing friends
The slim one
Call me VSG
Originally Posted by derickwm View Post
No
Originally Posted by B NEGATIVE View Post
Its very likely the 6w unit from the Predator.
EDIT:It is the 6w Predator unit,just asked Derick.
Its good for a GPU block and a small rad extra,not much more.
No
  • Less than 2 weeks and already a 9.04€ price increase?
  • If you must bundle, at least offer a choice between PWM and voltage control... PWM ports are typically at a premium.
Discussion Starter #13
You must probably be in the US and if it's the fact, than the price you're seeing is in USD instead of EUR. 84.99USD is pretty much 75.95EUR
Dam, I knew that... nother brain fart I guess.
Thank you.
1 - 16 of 16 Posts
