1 - 3 of 3 Posts
hi
i bought ekwb l360 kit and found ek supremacy mx cpu cooler for 115x shocket needs removing the backplate of of motherboard.my question is do u have to do these with all the ek supremacy cpu
cooler? i wud be happy to return the kit and get everything separate.
thanks.
EK Supremacy EVO uses a little bit different mounting. You don't need to remove stock backplate that comes with the motherboard.
I personally like the mounting mechanism of Supremacy MX. What is the point of having two backplates.. Also you can mount MX version tighter, there was some tests with Evo block using MX mounting mechanism and it yielded few degrees lower temps.
1 - 3 of 3 Posts
