1 - 20 of 35 Posts
STG3 VET
You read that right, 6Gbps. Seagate and AMD will be showing-off a prototype Barracuda hard disk drive with AMD prototype 6Gbps SATA chipset for the first time this week at the Everything Channel Xchange Conference in New Orleans. Yup, a world's first. Fortunately, the third generation SATA interface remains backward compatible with your old SATA 3Gbps and SATA 1.5Gbps disks and devices -- cables and connectors too. SATA revision 3.0 also brings enhanced power efficiency with improved Native Command Queuing for applications with heavy transactional workloads. No update to the official launch timeline was made so we'll assume that the first half of 2009 for retail devices is still in the bag. Hey, you weren't planning to purchase a new laptop or desktop before then anyway were you. Were you?
source
If repost pls let me know
Note that those benchmarks are of the interconnect and not of a single hard drive.
The average sustained read/write speeds of todays 3G drives are only around 50-70MB/s. The problem with hard drives today isn't bandwidth, its the spindle speeds. Modern sata 7200rpm drives don't even saturate the 150MB/s of the 1st gen sata, don't really see the point in this until they start making faster drives.
Originally Posted by 003 View Post
Pointless on anything but the very fastest SSD. Don't mention 15K drives, they use SCSI.
Raid 0 arrays will benefit from the extra bandwidth.
I just put in a RAID 1 array in my computer of some lower end drives, and I'm getting write speeds of 120MB/s!! I agree with you for sure!
No, they won't. SATA is a point-to-point interconnect. Each individual hard drive gets a dedicated 1.5Gb/s, 3.0Gb/s, or 6.0Gb/s connection to the SATA controller already. RAID is done at the controller level and not the HD interconnect level. A RAID0 with 100MB/s hard drives will perform the same regardless of SATA speed.
Agreeing with falsehood.
Doubtful, the only arrays I've seen that have 300MB/s + of bandwidth usage are large 8+ drive arrays on a dedicated raid 5 card.
Oh wow almost saturating the sata 1 interface bandwidth!
yeah, but RAID1 doesn't really provide you any benefit other than data security. write speeds surely wouldn't be positively affected.
yeah, but I have seen similar-sized arrays get in the 750+MB/s area. It really depends on how well you configure the array and the hardware you use.
I still have yet to see any motherboard based raid arrays break 300MB/s or even come close to it, thats what I was getting at.
Totally New to OCN
So what Raid COnfig would be needed to get the full speed?
SATA is a dedicated point-to-point interconnect between a hard drive and controller.
RAID is various methods of access hard drives to gain performance and/or redundency. RAID is performed by some form of controller.
They are two different things. Excess SATA bandwidth has ZERO impact on RAID performance.
yeah, onboard RAID solutions are typically rubbish compared to quality, dedicated cards.
Originally Posted by Licht
SATA2 bottlenecked my RAID array. It's out of date before it's predecessor is even here.
What? No, just no. SATA 3.0Gb/s did NOT bottleneck your RAID unless your individual HDD/SDD are doing 300MB/s.
1 - 20 of 35 Posts
