Do you remember the price of Intel previous popular chipset 865?
The entry model was cost 120~130USD.
After that, P35/P45/P55/P67 chipset entry MB price was even higher.
The entry model was 160~180USD.
Of course, the MB components and spec were getting better and more features.
Many friends were complaining the high price and miss the chipset 865 time.
Most customers are more prefer parity MB. At late stage of Z68, you can see some 100USD boards.
In April, latest Ivy Bridge launched, Z77 boards are more parity.
Z77 just launched, many MB makers all released ~100USD Z77 MB.
These couple years, NoteBook, Pad and SmartPhone share the internet devices market.
It pushes DeskTop very hard. The market competition and price are going lower.
Z77 board price back to parity 865 dynasty which is good for users.
CPU is Intel Core i5-3570K
Clock is 3.4GHz, supports Turbo Boost 2.0 and max clock is 3.8GHz.
Latest 22nm plus 3Dtransistors technology, physical 4 Cores, 4C4T.
TDP 77W, L3 Cache is 6MB. It's one of two Ivy Bridge K sku CPU.
3570K Backside
i5-3570K price is mid-end Ivy Bridge CPU. If you don't OC, you can choose cheaper i5-3450.
This review is entry Z77. CPU using K series can improve the performance.
MB is GIGABYTE Z77-D3H. The price is around 135USD.
PCB is standard ATX, 30.5 X 24.4cm which is quite rare design in this price segment.
Of course, there are some cheaper Z77 boards. However, they may cut some display ports or shrink the PCB.
Does lower spec Z77 meet your requirement or budget? I suggest you better to study more before buying.
Z77-D3H is blue PCB and white slots. Blue is my favorite colors. Overall, it's good looking.
If you prefer the black PCB board, there is Z77X-D3H for you which is 20USD more expensive.
Lower-Left Corner
2 X PCI-E X16 supports 2-Way AMD CrossFireX
When using Ivy Bridge CPU, the bandwidth is Gen3 X16 + X4
3 X PCI-E X1
2 X PCI
LAN chip is Atheros GbE LAN
Audio is VIA VT2021 supports 7.1 channels and High Definition Audio technology.
Design in Taipei
Lower-Right Corner
2 X White SATA by Z77 supports SATA3
4 X Blue SATA by Z77 supports SATA2
It supports hybrid RAID 0, RAID 1, RAID 5 and RAID 10. The max performance depends on installed SATA devices.
2 X 64 Mbit flash, Dual BIOS, TPM(Trusted Platform Module) connector
Upper-Right Corner
4 X DIMM DDR3 support 1066/1333/1600/2400(OC). DDR3 max capacity is 32GB.
It supports Extreme Memory Profile technology. Beneath is 24-PIN power connector and front USB 3.0
The PWM has 7 phases, 4-phase for CPU, 1 phase for VTT and 2-phase for GPU.
As 22nm Ivy Bridge CPU TDP, 4-phase design is enough for air-cooling OC.
IO
1 X PS2 KB/Mouse
1 X D-Sub / DVI-D / HDMI
4 X USB 2.0(Black)
4 X USB 3.0/2.0(Blue)
1 X RJ-45 LAN
1 X S/PDIF Optical output
5 X Audio Jacks
3570K Backside
Lower-Left Corner
3 X PCI-E X1
2 X PCI
Design in Taipei
Lower-Right Corner
Upper-Right Corner
IO
1 X PS2 KB/Mouse
4 X USB 2.0(Black)
1 X RJ-45 LAN
5 X Audio Jacks
