1 - 17 of 17 Posts
So there's this laptop, Acer Aspire V15 Nitro, and the specs are:
i7-6700HQ
8 GB of DDR4 RAM
GTX 960m
1 TB HDD
15.6" 1080p display.
52 WH battery
Backlit keyboard
It's on a tiny sale too, for about 5% off for ~940$ exchange rates taken into account. I was thinking of grabbing one, but I don't terribly need a laptop right now, I may need one soon, though. So, is it a good deal? And, are there any new mobile chipset coming out relatively soon that are worth waiting for?
And, does anyone have a laptop like it? I looked around Google for info on ability to install an SSD into it, without taking out the HDD to no avail. Any info on that will be appreciated.
Laptop Enthusiast
I have a laptop with pretty much the same exact specs. Though I have THIS thing instead. It's a powerhouse and it's by far nothing close to an "Entry Level" gaming laptop. It'll do Fallout 4 on Ultra without AA if that matters.
That's a good price for that machine though. I know the Acer will have a better, and much brighter, screen than I have on this Dell. The keyboard should be better too. But I'm unsure of the cooling which is what I'm most concerned about. A LOT of the more recent lower end laptops have been a bit on the sub-par side when it comes to cooling, unable to handle their temps at max load, etc, and throttle. That's why I bought this thing. It can handle max load for however long and has no issues whatsoever.
Ultimately, if you can get the Acer, you won't be disappointed with it for that price.
Thanks for your reply. Had no idea 960m was that good, I expected much less, I hope it fairs well in Witcher 3 and GTA V as well.
The Acer currently has the best price around here, that price would at best get you a 950m (which isn't terribly different from 960m, just clocked lower), and a 4720HQ, and no backlit keyboardm so Acer's price is great compared to others.
What I'm really on the fence about now is the lack of SSD. I'll want to put a 256 GB SSD in it, but also keep the HDD, if it's possible. unfortunately, this laptop doesn't have an optical drive, so I think I may need to exchange in the SSD for the HDD, which leaves me with too little space on the go, and a 1 TB SSD is far too expensive for me to consider now.
Laptop Enthusiast
Most laptops, including that one, should have an M.2 slot for another SSD... so technically you can install one AND keep the 2.5" drive you possess now.
That's how mine is. ^_^
Laptop Enthusiast
YES, confirmed! The Nitro V15 you listed does INDEED have an M.2 slot for an SSD.
Laptop Enthusiast
Brilliant! Thanks a lot for confirming that for me! I'll probably buy one then, just need to get the money together...
I'm assuming it's the model with the 4GB 960M? If so, that's a GREAT choice.
Plenty of games out there will eat up every MB you can give...
Laptop Enthusiast
Yeah, 4 GB version. I know... *looks at GTA V*
Dying Light uses 3.5GB at max details.
There are a few games that will VERY much benefit from that framebuffer.
GTA V you can probably do on High settings with no AA... but AA or FXAA or whatever is useless on a 15" 1080p screen. Everything is seamless already.
Discussion Starter #10
Well I don't have that game so can't comment, but yeah, 15 inches isn't large enough to have a hefty AA running on it.
Laptop Enthusiast
I mean, it's nothing to be impressed about, but the GPU runs skyrim completely maxed out with x8 MSAA... so at least it's on par with a GTX 580 in that regard. x3
Which for a GPU that draws only 50w, that's impressive.
Laptop Enthusiast
I do not have the game. If you're curious about the GPU in question, look up the GTX 750 Ti. It's literally that same exact chip except with 4GB instead of 2GB. Great choice for any gamer.
Phenomenologist
i got my sig rig laptop on sale for 1400 bucks... i know 440 bucks more is a lot of money, but the immersion is much nice... just keep checking for deals or wait for black friday maybe?
Discussion Starter #16
I don't live in the US, so black friday is a not an option. But I think I may wait for Polaris/Pascal launch, with the die shrink, we should get better and more efficient GPUs for laptops.
Laptop Enthusiast
1 - 17 of 17 Posts
