the order should be res > pump > rad > cpu > res.
you should also check out this and can try out ther voltages and etc.
hope this helps
hope this helps
Originally Posted by Klue22 ![]() gah sorry, keep forgetting, everything is in a single loop with the CPU first (directly after RAD) then the loop goes through both GPUs and back to the res |
