1 - 6 of 6 Posts
I need help getting my system to be stable at 3.6ghz. Ive had it running at 3.6ghz for over a year, but ive reached a point where my system is no longer willing to work with me.
So, my experience with overclocking...lets say Ive managed to go 3.6ghz for over a year and not have it stable since. My most common stability issue was the BSOD: STOP 0x00000124 error and I just didnt know how to fix it. I need to get it back up and running at 3.6 ghz, but stable this time.
Can anyone help me?
it may just be due to chip degradation... you might want to specify BCLCK, multi, voltages etc...
I am not an experienced overclocker, but those might help those who are.
124 bsod stop code means your qpi/uncore voltage is too high or too low. Try playing with that setting and see if that helps.
Can anyone help me?
0x00000124 is a VTT error. its called MCH/DRAM reference in the BIOS.
bump it to ~1.325ish volts and you should be golden.
1 - 6 of 6 Posts
