1 - 6 of 6 Posts
Couple questions here.
I want to be able to use this machine for every bit of folding power I can get out of it. (sig rig)
I am currently only folding on 1 4850, and I will set the other one up once i figure that out.
But right now, I am trying to get my cpu to fold along with the 4850, but when I install ( following stanfords directions) I get this message:
any suggestions?
Did you right click the install.bat and run as the administrator, and do you have a windows logon password set? IIRC that error is generally for not running as the admin.
No, But I tried and the Window will not open if I run it as admin.
Do I have to have GPU folding disabled to install?
You don't need to have the GPU client disabled to install the SMP client. Wish I could help, but I can't see your error message for some reason.
Discussion Starter #5
Edit, Figured it out. There was an old copy of SMP in the Windows.old file.
1 - 6 of 6 Posts
