Ethernet Settings Nforce 780i
1797 Views 3 Replies 3 Participants Last post by  iamtheonlystevo
Anyone know what I should set this stuff up as? I seem to be having latency issues and connection instability that my ISP swears is something on my end.
Device Sleep on Disconnect: Enable/Disable
Flow Control: Disabled/Rx + Tx Enabled/Rx Enabled/Tx Enabled
Interrupt Moderation: Enabled/Disable
IP Checksum Offload: RX + TX Enable/RX Enable/TX Enable/Disable
Jumbo Packet: 1514 bytes/2514 bytes/4514 bytes/9014 bytes
Large Send Offload V1 (IPv4): Enable/Disable
Large Send Offload V2 (IPv4): Enable/Disable
Large Send Offload V2 (IPv): Enable/Disable
Low Power Idle Mode: Enable/Disable
Low Power State Link Speed: Enable/Disable
Network Address: Not Present/ Value:xxxxx
Priority & VLAN: Priority Enabled/Priority & VLAN Enabled/Priority & VLAN Disabled
Recieve Side Scaling: Enabled/Disabled
Speed/duplex settings: Auto Negotiation/10/100/FD/HD
TCP Checksum Offload(IPv4): RX &TX Enabled/RX Enabled/TX Enabled/Disabled
TCP Checksum Offload (IPv6): RX &TX Enabled/RX Enabled/TX Enabled/Disabled
UDP Checksum Offload (IPv4):RX &TX Enabled/RX Enabled/TX Enabled/Disabled
UDP Checksum Offload (IPv):RX &TX Enabled/RX Enabled/TX Enabled/Disabled
VLAN Id: Value
Wake on Magic Packet: Enabled/Disabled
Wake on pattern match: Enabled/Disabled
WakeOnLAN From PowerOff: Enable/Disable
I'd appreciate any info on these settings, if you're wondering I'm advertised a 6meg download/ 384 upload and my speeds bounce around from 900kbps - 5.5 Meg, differing just about every time I speedtest it. My latency is ALWAYS horrible, no matter how fast the connection is running. I've been dealing with over 300 ping to Chicago, which is 3 1/2 hrs away.
1 - 4 of 4 Posts
Originally Posted by Sanders54
Uninstall NAM - Netowrk Access manager or something (NVidia software which is useless and bogs down system)
Agreed. The nvidia network software "prioritizes" certain network traffic, but it's always caused problems for me. Uninstall.
1 - 4 of 4 Posts
