1 - 11 of 11 Posts
i have a hd5770 and i am using catalyst center i also use everest to monitor my temps.
the problem i have is everest wont let me monitor the gpu temps even though it has no problem recognizing the card or gpu as its the latest version.
i wonder has the option been removed because catalyst does the same job?
i dont and never have liked catalyst and would like to use everest instead
anybody have the same problem?
Discussion Starter · #2 ·
bump: no one having this problem?
Discussion Starter · #6 ·
Originally Posted by awaizy
If you want to consider an alternative software, Hwmonitor does the trick.
ive always used everest but i think that i am using ati"S software it has stopped it.
i use everest ultimate and it wont let me see the temps of my 5770
i use everest so the sidebar app i have works right
5.00.1650 is my build
Discussion Starter · #11 ·
Originally Posted by Hennessy
I've got the same problem 5.30.1900 build :S
yea ive the same latest version
maybe its a bug in everest.
1 - 11 of 11 Posts
