im mining a certain sha3 coin and everytime i run the bat file
it starts mining no problem but after a few minutes sometimes seconds i would lose internet connection
i used a cat5 cable to share a wifi connection between 2 computers that are mining the same coin and the (host) has the wifi card has been running fine 24/7 while sharing the connection and mining.
the (client) main pc i use is connected to the host via lan cable and the connection is bridged and i have no problem using the internet and gaming and streaming.
the client has windows 8.1 and the host has windows 7
any info needed i can provide but im not sure what the problem is i think it is windows 8 it self...
i also have synergy installed if it matters
any help would be very appreciated thank you
