1 - 20 of 37 Posts
Discussion Starter · #1 · (Edited)
Hey guys,
I recently loaded ACV and tied to tune my GPU and I noticed there was a particular behavior with the frame rate/time with the game. Do you have any clue what could cause this? It seems it is not doing it specifically with this game. Even when I load RDR2, the FPS does the same fluctuations. Any help to diagnose the problem will be greatly appreciated!!
2517694
Your memory is at +1300MHz ??? If this is the case, I can guarantee you are WAY WAY over the limit there. Memory error correction could be kicking in due to stability. Set memory at default speeds and test again.
Discussion Starter · #3 · (Edited)
Actually, I can OC to 1500 with no issue. I tried with no OC on core, memory, power limit, voltage and the issue is still there :/.
2517713
Okay, but for the purpose of trying to figure it out leave it at default incase. What PSU, Ram (speed and timings) ??
PSU: 850 Gold
RAM: 3200 18 20 20 36
By the way, I've noticed the change just now cause I've not been gaming a lot lately. I've not installed any programs and download any suspicious app. It could have been like this for more than a month and I just noticed it. My next step is to format my OS drive.
PSU: 850 Gold
If you are playing at 1080p, you could and might be CPU bound. Does this happen to any other game ? Is your Windows 10 OS old and cluttered ? Do you have the latest drivers installed properly and old ones removed via DDU ?
Playing at 4K. Other games the FPS fluctuates like this at the same rate. Windows is updated at the latest build and I removed any old drivers with DDU. I'm kinda out of options right now that's with I tried this forum...
Why does the BM incorrectly display your resolution is see 1080p and some weird resolution in the 2nd picture ?
Download GPU-z, run a benchmark in Windowed mode, have a look and see if your GPU is running at the full x16 gen 3 or gen 4 (not sure if ur board is gen 3 or 4). I have had similar issues what you describe, more commonly on riser cables where sometimes they don't make good contact with GPU PCIE Express slot.
Discussion Starter · #9 ·
Oh yeah, displaying the game in borderless mode, will upload the second picture at the correct resolution, my bad.
Here you go:
2517716
Sorry, this is what I meant for you to look at.
2517719
Reactions: Iwamotto Tetsuz
Hmmm interesting.
What are your games installed on ? SSD's NVME ? HDD ?
Discussion Starter · #13 ·
Hmmm interesting.
SATA SSD. Just like mentioned before, I've just notice the hiccups lately. I think I'll just format my c: drive and start from scratch.
Hmmm I'm not too sure at this point. Perhaps wait for others to make any more suggestions.
Other things you could try are:
  • Update your Motherboard BIOS
  • Fresh Windows 10 OS install (assuming its old and cluttered)
  • Roll back one or two driver versions for GPU and re-test
That looks much better... Crappy new drivers id say was the issue.
Discussion Starter · #19 ·
That's awkward lol.
The fact that it worked, but then a reboot caused it to re-occur could mean an OS issue. Hard to say unless you do a fresh OS install.
Yes, I'm downloading Windows media creation tool just now... -_- BRB!!
1 - 20 of 37 Posts
