Originally Posted by
tulipdu
Thnx guys for your opinion
And glina, I did some searching and totally agree with the fact that "7950 is more bang for your buck".
But can you help me a little bit more in choosing between?
HD 7950 Vapor-X OC Boost or HD 7950 DirectCUII TOP V2
And if possible what about their overclocking potential.
The Asus is said to be voltage locked, so you should expect no extreme overclocks with it.
That being said, you should still be able to get 1050-1150MHz with stock volts and this with the quietest cooler of any HD7950 around.
The Sapphire on the other hand is not voltage locked, but if you up the voltage and push up to 1200MHz and higher, the fan noise will get pretty annoying - for me personally it's not worth it.
The 1100MHz I get with stock volts is a sweet spot and this is what I run as a daily overclock. The fan speed does not exceed 2500rpm and is unobtrusive, but probably louder than the Asus.
You may also consider the Sapphire DualX. It's said to be as quiet as the Vapor-X, also voltage unlocked AND cheaper. Also it's 2 slot wide instead of 2,5 of the Vapor-X so will be easier to Crossfire if you choose to do so in the future.
The unlocked voltage can also be used to undervolt. I can run 1000MHz core with 1.02V (0.96V effective) which is pretty much silent. If I ever go Crossfire, I will surely undervolt to minimize combined power, heat and noise.
The Asus is 3 slots wide so you will not be able to Crossfire on most typical motherboards.
