1 - 4 of 4 Posts
Hey guys i just got my 2 GTX card in my rig today.. and they run awesome but after i got done playing some BF2 ,,, i opened the side of my case to move a wire off of the card and i touched the big black heatsinks ( i guess thats what u call the things around the EVGA card ) and it was really hot.
I checked the temp on my cards and they were 51 degrees. alot cooler than my 6800GT was. do u think those big black things are pulling alot of heat from the cards since there so hot. or should i be worried about getting some more cool air into the case.
That temp is fine for your card, cooler is always better though. Id try to get a bit more air flow through the case, that should help a bit.
edited: typo
It's pulling heat of the the GPU. Considering 51c is right around 123F, that is why it felt hot to the touch. Under full load your graphics card can get rather hot 65-70c, as long as it doesn't go over 90c your fine.
Yeah, cross flow is always better. You always want cross flow from the front of the case to the back, it keeps any dead spots from forming and causing hot spots.
But yeah, 51* is very good
1 - 4 of 4 Posts
