EVGA 9500GT 512MB - Whoa!
1227 Views 11 Replies 10 Participants Last post by  BlankThis
Ok, some of you might think this little card is, uhh, crap, can't handle anything.
I went cheap on this GFX card and went good on the rest of my PC.
But this 9500 GT is awesome, I just got done playing the Fear 2 demo on max settings, 4x anti aliasing, etc. Crazy high FPS.
This card has handle everything I have put towards it, no lag on anything.
I plan on upgrading to a 9800GTX, maybe in a month or two.
But for those who want a good cheap video card get this if you don't have a lot to spend, or want this to fit in your budget.
This is the one I have:
http://www.newegg.com/Product/Produc...82E16814130378
I would have gotten this one in January, but didn't see it:
http://www.newegg.com/Product/Produc...82E16814130395
Comments?
1 - 12 of 12 Posts
What resolution did you play at?
Also, for about the same price, you could get an 8800gs Used, so thats probablly a better option to consider.
If it's that good, is there much point in getting 9800GTX? why not wait to see if prices of other cards drop a bit?
Originally Posted by Domino
and what res? 1280x1024?
Seriously. I had a 9500GT for a while (attempting PhysX). Mirror's Edge at 1680x1050 couldn't handle AA at any level.
i have a friend with a 9500gt and he loved it soo much he bought another for sli! i watches him play crysis @ 720p on high with 30+fps
Dont get a 9800GTX, save up and buy this
http://www.newegg.com/Product/Produc...82E16814130448
I was playing in 1280x1024. And it was lag free wonderful, max temps on the card got to 54C.
I will definitely look towards getting that card, but I heard its only a rebranded 9800 gtx.
No, the rebranded 9800 GTX is the GTS 250. The GTS 260 is far from a rebranded 9800.
So this is a good one?
Quick question, my board doesn't support sli, only crossfire, and I kinda want to keep the 9500 gt. Would I be able to use it as a physx card?
Yes. Just plug it in your secondary PCI-E slot and whatever card you decide to upgrade to in your 1st or primary PCI-E slot. Then just enable PhysX in nVidia Control Panel.
~B~
1 - 12 of 12 Posts
