EVGA has removed the Guest RMA option. EVGA customers are left in the dark on how they can check the remaining warranty length on used evga cards, before purchasing a used one.
The only comment so far made by EVGA is this one
Source
*update* 3/03/2018
If you want to verify evga product remaining warranty, you have to contact evga support to do so. IMO they should of turned the "Guest RMA" web page into a "Warranty Check" web page. That wouldn't make it hassle to verify product remaining warranty.
EVGATech_BrandonS
I'm sorry for the confusion; we have now removed the Guest RMA option, and all products will need to be registered and a standard RMA submitted instead.
Source
*update* 3/03/2018
SourceEVGATech_JeffP
Hello,
At this point in order to check the warranty on a non-registered product you will need to contact us though phone or e-mail, if your product is registered but was not purchased through an authorized retailer you can also submit a ticket to find out the remaining warranty length on a particular serial number. This is subject to change without notice as with all warranty terms and conditions.
