Status
Not open for further replies.
1 - 20 of 217 Posts
PC Enthusiast
Originally Posted by EVGA_JacobF
Stay tuned...
source
Looks like the GTX 580 lightning, with the extended hight, not liking the cooler though
PC Enthusiast
Originally Posted by driftingforlife
I like the fact it doesn't dump air into your case but it looks CRAP!!!!! also link don't work.
Actually, it looks like it does dump a little beat of heat above the SLI connectors.
I don't think so, if you look it isn't actually part of the cooler, it is an add on and I think the notches are for looks.
AMD Overclocker
Pepper needs new shorts!
PC Enthusiast
Discussion Starter · #9 ·
Originally Posted by sLowEnd
They stuck 3 power connectors on their previous Classified cards too.
It's nothing new.
But the 285 and 480 Classy's look, well, classy. This thing looks like a cheesy, oversized, mutated Fermi turd.
I think these cards that are ment for overclocking should just come with a waterblock as standerd for 2 reasons.
1. Nobody makes waterblocks for the extreme cards.
2. Extreme cards just shouldn't be alound to run on air.
AMD Overclocker
Originally Posted by DrDarkTempler
Ok.... What The hell is this thing? look like mini electic leaf blower.... or those homedepot floor dryer blower lol
What you fail to realize though is that this design is a lot more functional than that of the lightning or matrix cards. This card doesn't have any part of the cooler hanging over the sli connectors which means 4-way sli is possible natively. Also, I quite like the design because it doesn't blow all that hot air into your case. And depending on the power delivery and quality of the chips, we could see a real record breaker here.
Thing is, is that these extreme cards are really meant for breaking records on ln2. So what is the point of putting a waterblock on them when that would increase the cost substantially to us and the overclocker buying them will have to take the water block off anyways?
1 - 20 of 217 Posts
Status
