1 - 20 of 45 Posts
Is this normal or too hot? On Evga Gtx 780 SC ACX i am reaching 80C when playing Crysis 3, FAR CRY 3.
Max gpu boost is 1110mhz.
I have case Cooler Master 590. On the same case my Asus 780 DirectCuII reaching 72C.
DTR Enthusiast
My first guess would be that you're not getting enough airflow. Do you only have the 120mm fans that came with your case?
Also, try removing your side-panel to see if your temps decrease.
DTR Enthusiast
I know, but since you have an ACX cooler, it dumps heat back into the case, rather than blowing it out the back.
EDIT: Thought your last post was to me.
DTR Enthusiast
Originally Posted by sew333 View Post
So its normal? Try to change to other example or not?
Its within spec, but If I were you, then I'd be more comfortable at 70°C.
Take off the side panel and monitor temps again.
DTR Enthusiast
Sounds about right with 65% fan speed actually.
Problem is most likely airflow in your case.
DTR Enthusiast
So change to other example or what now?
Just tell us if your temps have dropped or not. If they haven't then your fan speed is too low or your room is too hot.
DTR Enthusiast
Just add in a 120mm fan on the side panel and the top of the case and that should help out temps. If not, then its your room temp.
1 - 20 of 45 Posts
