EVGA Hadron Air Chassis - Tips & Compatibility Guide
3.9K views 13 replies 8 participants last post by  Coreda
#1 · (Edited by Moderator)
"Why sacrifice appearance and size when choosing a performance rig? The EVGA Hadron Mini ITX chassis was designed to not make any compromises." - Hadron Air manual
The Hadron's appearance and size are the main reasons owners decide on this chassis, however it's not without some compromises. As long as you are aware of what limitations the case has, and plan your parts around it, you shouldn't run into many problems.
Your choice of components is primarily limited by size. It was worth doing the extra research to find the appropriate parts, but it wasn't easy. Hopefully this guide will provide some useful info for others interested in the Hadron.
Things to know:
  • CPU cooler clearance is 140mm, with some reporting around ~2mm extra clearance. Your options are mostly low-profile or top-down coolers. See a compiled list of compatible coolers that users have built with in the following section. To ensure maximum clearance compatibility low profile (LP) memory is worth purchasing. Furthermore the chassis has no CPU cut-out, reducing the ease of cooler replacement.
  • GPU clearance is 10.5"/267mm long and no longer, unless you're willing to do some modifications. The EVGA 780 reference and ACX will fit, for example, but longer cards are out (see EVGA's list of incompatible cards). For an idea of how longer cards fit see this user's build with an EVGA 780 Classified, which required bending and cutting the case tabs to install. Also SLI isn't an option, although not surprising.
  • Aftermarket GPU coolers are generally not recommended for the Hadron. Although unfortunate as this limits the card's cooling (and noise) potential, the advice is sensible as it improves the case's temps by pushing all the hot air out the back. This still hasn't stopped some from choosing aftermarket designs for the Hadron, although an owner of both noted their ACX card ran up to 10c warmer than the reference version with the same settings (see also this benchmark comparison ). It should be noted the Nvidia Kepler series chips will always stay within the max target temp set within the software however.
  • It's preferable to buy a mini ITX motherboard that has the 24pin connector on the right side, rather than at the top, as the PSU cabling is sized to fit and it makes for far more suitable cable positioning within the case. The EVGA Z87 Stinger, ASRock Z87E-ITX*, and ASUS Maximus VI Impact are such boards (note that the Stinger lacks in-built Wifi).
  • The Hadron Air lacks support for water cooling, although some have still remarkably managed to pull it off using some modifications. See the Hadron Hydro for an officially-supported water cooling chassis.
  • There is no dedicated cable management, so it's best to take a look at some of the ways other owners have arranged their cabling to get some inspiration. See this owner's short illustrated post for some ideas. The illustrated Split View photo above shows my own Hadron with the USB 3.0 cable tucked behind the motherboard.
  • The included gold-rated PSU can handle up to 500W, and EVGA has stated it can handle up to a GTX 780 Titan. Best to do some calculations for your expected power output nonetheless.
* For users of motherboards with the Foxconn CPU retention bracket it's worth noting the mechanism is rather stiff and will require some force to clamp the CPU in place. Initially I was concerned as it made two surface marks/dents in sides of the CPU where the bracket contacts, but I have read that this is common for the Foxconn 1156 brackets ( source ).
More specifics:
  • The stock 120mm case fans are installed as exhausts. If you're planning on flipping the fans to make them intake a tip to easier screw thread creation is to heat the screw using a lighter for a few seconds beforehand (only needed if the plastic is being difficult). Use a larger screwdriver if you see the heads wearing.
  • For users intending to use intake case fans it should be noted there is little space between the perforated grill of the chassis and the circular fan cut-outs - they are almost flush. Because of this very thin dust filters will need to be used ( details ).
  • If you're planning on only using SSD drives, and won't be installing the internal slimline optical drive, with some modifications a number of owners have removed the drive cage in the upper-right of the case for additional room.
  • The headphone jack on the chassis' side panel can have issues with static interference, depending on how the cables are arranged inside. This ground loop noise can be reduced/eliminated by insulating the circuit board with electrical tape ( instructions ). I found it best to position the PSU power cables so they're not touching the board, however using the direct on-board audio out is still typically clearer.
  • The included PSU uses the Delta FFB0412VHN fan which is spec'd @ 45db . However EVGA have stated their custom curves have it at around 30db under load. In my build it's the loudest fan in the case, producing a constant whirring sound. I found this personally the only main disappointment of the Hadron Air chassis, although depending on environment it mightn't be audible. Because of this some have taken to lubing the fan with machine oil, modding their PSU with a quieter fan (such as this owner's post with DIY instructions), or even replacing the PSU entirely .
Compatible CPU coolers
This is by no means a comprehensive list, but should cover the most commonly used coolers used with the Hadron.
Seen in builds:
- Arctic Freezer 13 [ 1 ]
- Cooler Master Hyper TX3 [ 1 ] - w/ either single or dual fans attached in a vertical orientation.
- Cryorig M9 [
- EVGA mITX CPU Cooler [ 1 ] - officially supported.
- Noctua NH-L9i [ 1 ] - specifications state compatibility with all RAM and PCIe cards on mini-ITX boards.
- Noctua NH-U9B SE2 [
] [ 2 ] - w/ both 92mm fans able to be attached in a vertical orientation. Low profile RAM was required in my build to clear the fan's side clips.
- Phanteks PH-TC90LS [ 1 ] - see photos, unlisted on parts list. Note: lacks AMD socket support, and is incompatible with Intel 2011 sockets ( reviews source ).
- Thermalrite AXP-100 [ 1 ] - has room to add a larger replacement fan, seen here with a Scythe Gentle Typhoon AP-15.
Also seen in builds, but with caveats:
- Noctua NH-C14 [ 1 ] [
] - only when installed in the low-profile config, and requires one of the Hadron's top 120mm fans to be replaced with a 120x12mm fan ( source 1 , and 2 ). Be aware this is a difficult cooler to work with and may block components depending on the board used.
- Cooler Master Hyper N250 [ 1 ] - a decent cooler, but the mounting system is outdated and known to rotate if bumped - just fits at 141mm high. Note: the owner of the linked build has since moved on to a Noctua U9B SE2.
May be compatible based on dimensions:
- Thermolab BADA2010 [ FrostyTech review ] [ site ] - a little known Korean cooler that benchmarks both in heat and noise similarly to the Noctua U9B, almost bought this myself but lacks an international warranty. Unsure of exact clearances.
Links:
This article is a work in progress, as such any additional comments you have from your build experience would be greatly appreciated.
#2 ·
This looks awesome man. I'll be sure to use some of the information here and also give credit where needed. Something to mention - You may want to source a few of the users (if Evga forum is needed) for the drive cage removal.
l9i - confirmed - http://forums.evga.com/tm.aspx?m=2082325
#5 ·
I recently completed my first build, which was a Hadron Air (my build here - http://pcpartpicker.com/user/grantcov/saved/3RD0 ). Two things I'd love to add to this discussion:
1) As you can see I put an EVGA GTX 780 with the ACX cooler in my build. I have noticed that the bottom of my case gets fairly warm (I'm reluctant to say hot because its not like painful to the touch). I didn't realize the cooler would be an issue until after I'd purchased and I figured I'd go for it and so far there have been no issues. I'm new to building computers so I don't know how to get temp readings or anything like that except when I'm booting the computer up, that being said I'd be happy to do a temp reading while playing a game to give you guys an idea of how hot things are running, if someone explains to me how to do it.
2) I went with the NH-U9B and was unable to get both fans attached due to my ram. Should I be concerned about that?
Thanks for making this thread!
#6 ·
@Stalanium Great that you're interested in some temp readings for ACX card.
1. Found a good thread here which explains how to set up on-screen displays (OSD) of temps during games. MSi Afterburner can be used or EVGA's Precision X app, as they both follow the same settings afaik. HWiNFO mentioned there is what I use to monitor CPU temps.
2. If it was standard profile memory I'm guessing it was because of the fan clips overlapping? From the benchmarks I've seen the difference between a single fan and dual is about 5c, so it's not a major difference. As mentioned above you can always check the temps with HWiNFO if you'd like more info. I'm idling with the dual fans at around 31-34c using the blue low-noise voltage adapters, but haven't tested yet under load.
#7 ·
Sorry for length of time between my posts - finally downloaded the software last night - got HWiNFO and EVGA Precison. So I was able to get the video card up to 100% and my temps were hitting 79 C on the GPU. Which I know is right up against the top of where you want to be, so that's a bit worrisome.
For CPU temps, I can't tell which temp in HWiNFO I'm supposed to be reading .
One thing I'm wondering though is that in the EVGA Precision app, the target temp is set to 79 - so if I lowered that would I be at a lower temp when I hit 100% or is that just coincidental?
#8 ·
For HWiNFO CPU Package is the main one to look for, also Core #0 - Core Max give individual readings as well.
Kepler series GPUs will max out at whatever the target temp is set to, so in your case 79C. You can lower the max temp simply by changing the value, which will either lower the clock speed or increase the fans to reach the new target temp depending on what you've set.
From my understanding the difference between reference and aftermarket fans with regards to measuring temps, and when there is enough airflow, is if the card can perform equally as well at a lower target temp, not to mention lower noise as well ( more info here ). The benefit is the user can always manually set custom curves for the performance of their GPU to their liking with apps such as Precision X, but most just leave it with the stock settings which mightn't be ideal.
If anyone has any further clarification they'd like to add feel free to share.
#10 ·
@Travellerr: the best to ask would be the Hadron Air OT for a more general idea, as I haven't installed a GPU yet and currently have my Hadron placed in a cabinet. Naturally temps will differ depending on their heatsinks/fans and custom profiles, but I haven't read any owners finding heat an issue so far.
That said, after running a stress test my Noctua (with the low-noise adaptor) was keeping the CPU between 45-64c, while the rest of the sensors seemed about normal. Higher than it likely would be if it were on my desk, but in normal use I'm not stressing it so it usually runs cool.
