EvGA OC Question
378 3
I have a 7800GTX OC to the max rivatuner would let me. Everything is running perfect. idle temps are 35c and load 41c. no ghosting lines or snow dureing benchmarks. I feel I can get some more out of it. Any way to bypasss the pre OC test.
1 - 4 of 4 Posts
Ya if you go under the power user section in riva tuner and its under something like Overclock/General/nvidia or something im at school so I cant check it will be like InternalClockTest and right click it and set it to 0 and there is another one that says test in it set that to 0 also
1 - 4 of 4 Posts
