The difference is that the SC version is slightly oced from evga. If you can get it cheaper thats better for you. But also it doesnt mean that it wil oc better than the non-sc one.
The stock Reference card and the SC card are identical just a factory OC on the SC. The Classified uses a beefed up PCB.
The cooler whether the blower or ACX does not change the card specs at all besides temp and direction of air flow. the blower is good for low airflow(air leaves through back) cases and the ACX for higher air flow( air is left in case while cooling GPU better and needs to be removedwith good case flow)
1 - 7 of 7 Posts
