1 - 8 of 8 Posts
Manual breath enabled
Hello,
i wanna expand my H240X with a 120mm Radiator and a waterblock for my r9 390 nitro.
Here is the list of items that i saw/what i picked so far:
Radiator
http://www.highflow.nl/radiatoren/1-x-120mm-120/phobya-g-changer-120-1.1-black.html
Tubing
http://www.highflow.nl/slangen/3-8-slangen-5-8-od/primochill-primoflex-advanced-lrt-3-8-id-5-8-od-crystal-clear-pflexa-58.html
Fittings
http://www.highflow.nl/aansluitingen/fittingen/alphacool/alphacool-hf-screw-connector-g1-4od-10mm-3-8-id-5-8-od-deep-black-17087.html
http://www.highflow.nl/aansluitingen/fittingen/alphacool/alphacool-hf-screw-connector-90-g1-4od-revolvable-10mm-3-8-id-5-8-od-deep-black-17081.html
Waterblock
Alphacool NexXxoS GPX - ATI R9 390 M01
Coolant
http://www.highflow.nl/watercooling/koelvloeistof/kant-en-klaar/feser-aqua-ultra-pure-water.html
I dont wanna spend to much, but i want to overlock my gpu a bit^^
Are this parts a good choice? does this shop has some better items for my needings? Do i need a Reservoirs?
Regards
Streetdragon
Shooting down fallacies
Looks good other than the fittings. Something in the back of my mind is nagging me that there is an issue with these fittings, but I can't quite remember what it is. Given what they stock, I would stick with EK fittings if possible.
Discussion Starter #4
Discussion Starter #6
Thx i will get that. And one of this blugs. Everything that helps is good xD
Discussion Starter #7
I swiched to a other radiator, because i thought: why not install it outside of the case?
Not it is a Phobya G-Changer 240 V.2 - Full Copper
everything is dry
Thx @ciarlatano !
everything is dry
Thx @ciarlatano !
Looks good!
1 - 8 of 8 Posts
