I'm currently running a Heakiller 3.0 LT in my loop.
My i7 runs really hot compared to others I've seen.
4.3ghz @ 1.28V I idle around 38c (which is fine) but under load it immediately hits the mid 60's and eventually works its way into the low-mid 70's where it settles. If I kill the stress testing it drops immediately down to very low 40's and settles back in the high 30's after a minute or two.
I've always felt like the HK just cant pull heat off this thing fast enough to keep it cool.
I eventually got around to lapping the CPU and block (400-600-800-1000-1500) and didn't see any decrease at all. I've reseated and tried different mounting positions and pressure applications. No help at all. It seems with this block and this CPU I'm doomed to hit 70C
Water temps only rise 2c under full CPU load (from 28C to 30C - sensor in reservoir, before radiator)
Last time I flushed my loop the block was perfect. I only use PT + Distilled.
If I'm folding on my GTX480 + CPU I have no doubt it'd be in the 80's.
So anyways, enough with the background.
I'm thinking about an EK Supreme HF. But I can't justify the cost if it's not going to help me much.
Any advice?
Any advice?
