The reviews I've seen of TECs have all used them exclusively as a CPU coolant, and found that they aren't powerful enough to dissipate the CPUs heat. I therefore am wondering whether it isn't better to use a standard radiator to dissipate the bulk of the heat from the CPU, and then run the water out the cold end of the radiator and then over a TEC cooled waterblock. Then the TEC would have a much lower delta to overcome and basically just serves to bring the ambient water to below ambient. Using a low-flow high-turbulance block on the CPU could also reduce the workload on the TEC. Have you tried this? Would it work?
Thanks. First post, hope the format is okay.
