Status
Not open for further replies.
1 - 20 of 910 Posts
EDIT: The page is down. Removed because they probably posted the pictures too early I reckon. Oh well, I already took a copy of them so no problem
Nvidia has detailed its latest high end graphics card, the GTX Titan, confirming its existence with some impressive numbers that should cement its position as the world's fastest GPU.
Built around the GK110 Tesla technology first used in the Titan supercomputer - hence the name - the GTX Titan is Nvidia's most powerful graphics card to date, with a whopping 2,688 CUDA cores and 7.1 billion transistors, which produce 4,500 Gigaflops of processing power. Each card comes with 6GB of GDDR5 RAM, running along a 384-bit interface which should be more than sufficient for playing the latest games at above HD resolution. It's DirextX 11.1 compatible, so should support all the latest graphics tweaks such as tessellation, and Nvidia's own PhysX physics effects.
Designed as a single-GPU replacement for the current top-end GTX 690, which is actually two GTX 680 cores bolted to one PCB, the GTX Titan promises improved performance while using less power and producing less heat. A redesigned cooler with an extended aluminium heat stack dissipates heat faster than Nvidia's current design, while the 90mm fan is tied to both RPM and voltage control to more accurately determine when to kick in. With a TDP of 250w, you'll certainly need it.
Perhaps more exciting news is the addition of GPU Boost 2.0, an evolution of the software introduced with Nvidia's 600-series graphics cards. Built into the video driver, GPU Boost 2.0 will let Titan owners overclock and overvolt their cards, with higher limits than with previous cards and optimisations for water-cooling setups.
http://www.expertreviews.co.uk/graphics-cards/1297972/nvidia-gtx-titan-graphics-card-announced
"Perhaps more exciting news is the addition of GPU Boost 2.0, an evolution of the software introduced with Nvidia's 600-series graphics cards. Built into the video driver, GPU Boost 2.0 will let Titan owners overclock and overvolt their cards, with higher limits than with previous cards and optimisations for water-cooling setups."
Discussion Starter · #13 ·
Oh yes I noticed that one
This is the quote from the article
The one sticking price will almost certainly be the price - Nvidia would only confirm RRP pricing with us today, as it will be up to its hardware partners to set their own prices when the cards launch later this week, but you'll easily be paying over £800 per card. We'll have to wait until then to see whether the benchmark scores can back up Nvidia's claims that the Titan is the fastest card around, but the early indications look promising.
Originally Posted by Sheza View Post
Mentioned to be 'later this week'
RRP of over £800 which I expect would mean around $1,100 - $1,200 maybe? Or are UK prices even more ridiculous than I thought when compared to the US?
if its 800 UK then it will be about the same in USD... So 799-899
Originally Posted by marc0053 View Post
Why compare 3-way sli Titan with quad sli gtx 690 and not 1 titan vs 1 gtx 690?
Im curious what sli Titan would bring vs. 690 sli. According to the chart it might be much closer then we originally thought. In fact 690sli would be faster in some cases according to the chart.
Discussion Starter · #17 ·
They just removed the article. Nobody else have posted any news about Titan so I guess they were a little early so they had to pull it. Good thing I copied the pictures before that happend
Something's gone wrong
We can't find the page you're looking for, try checking the address you typed in. If this happens a lot you can email us at [email protected] and we'll have to look into it.
Looking Ahead
Originally Posted by TAr View Post
Realese date any one?
Last I heard was 21st available in stores and reviews may be out 19th or 21st also.
The title says fastest gaming system, but I guess Titan is slower than a 690 so it wouldn't look impressive. They should have stacked it up against a 680 as well IMO...
Originally Posted by elletrix View Post
And still no price or release date.
Because it would lose against the 690
it should be cheaper than the 690, then. i predict $600.
1 - 20 of 910 Posts
Status
