Sup all. I need a little help from the experts on which ram would be the best for my system:
http://www.newegg.com/Product/Produc...ubCategory=147
Originally Posted by prodigyru Sup all. I need a little help from the experts on which ram would be the best for my system: http://www.newegg.com/Product/Produc...ubCategory=147 |
Originally Posted by Ste What's the rig going to be used for? |
Originally Posted by prodigyru I want to upgrade for my rig to 2GB RAM (see signature below). I'm in love with my current 1GB Ballistix but they are a bit pricey for 2GB kits (arround $300) |
Originally Posted by pbasil1 this seems to be the best ram and its cheap too...http://www.newegg.com/Product/Produc...82E16820227066 |
Originally Posted by sccr64472 Just buy another gig then to save money. DDR is on it's final stretch and you'll be buying DDR2 with your next box, so keep it cheap. It'll run fine and will only matter in benches, so don't fret running 4 DIMMs. |
Originally Posted by prodigyru It seems that this particular ram has bad reviews ![]() |
Originally Posted by prodigyru I made a mistake buying 4x512 ram. It killed my overclock. I can only get it to be stable at 2.2GHz with 4 sticks of ram. |
Originally Posted by sccr64472 Show me a single credible negative review that doesn't come from an anonymous NewEgg poster. Keep in mind that Newegg "reviews" have 0 guarantees that the poster has ever even owned the product. If you read enough of those, you'll see that a majority of them don't even understand computers. You'll see lists of what they supposedly own and it will include DDR2 with AMD processor, 2 ATI cards in SLI,etc etc. Show me a legitimate review with negative results.... |
Originally Posted by sccr64472 That's your motherboard more than anything. If you still have the sticks, I'd get a motherboard, not more ram. |
Originally Posted by prodigyru My MoBo overclocks perfectly. I had owned a Diamond Flower Boards before and this mobo overclocks just as well. With 1GB (2x512) it is perfectly stable at 2.6GHz. But as soon as I add an additional 2 sticks - the entire system craps out. I tried every possible troubleshooting method i knew, losen timings, running at 2T, Dividers etc... but I can only get it to run stable at 240MHz (considering that this ram is rated at 250). It won't even post at 2600. ![]() |
Originally Posted by prodigyru sccr64472 to be honest with you I don't want to switch to another board. Most of good OverClocking boards have this same issue when running 4 sticks of ram (including my previous board DFI Sli-Dr). I see that you are pretty happy with your 2 sticks of 1GB Ram ![]() I'm now down to these 2: http://www.newegg.com/Product/Produc...ubCategory=147 |
