what is it? how do i set one?
what do i look for in my bios if it doesn't directly says divider?
help!
help!
CPU/RAM Ratio, FSB/RAM Divider, etc - This allows you to run your mobo and CPU at a different clock speed than your memory. However, generally w/ AMD boards, a ratio of 1 (1:1, 3/3, 4/4, 5/5, etc) will yield the best performance. Running your mobo and CPU at 200mhz FSB w/ a memory ratio of 6:4 (memory running at 133mhz) will not be very advantageous. |
