1 - 20 of 22 Posts
Admittedly, GPU directly promote the development of a graphics card cooling technology, such as AMD has its own high-end graphics cards in the full introduction of the "hot plate vacuum chamber are" cooling technology. In this week's Fusion 2011 Conference, AMD once again decided to introduce the next generation of the new Radeon HD 7000 graphics card cooling technology, that is, "the hydraulic chamber cooling technology (Liquid Chamber Cooling Technology)".
Source
404 Title Not Found
Is this going to work whichever way the gpu is positioned or is it going to have an arrow saying this side up??.. ......
Originally Posted by Sauerkraut;15299839
I know all the Intel fanboys are excited they get to bash AMD, and I know all the AMD fanboys are heartbroken, but why do you bring up a processor in a news story about a GPU? Does everyone on this board just look for every excuse they can to talk about BD? It has its place, in fact a few places... Go look for them in the AMD Processors section and lets keep this about the GPU.
On topic: Sounds awesome, but whats the likelihood of leaks? The tiniest fracture could be catastrophic. More so is this proven technology on any current gen high heat equipment?
This.
Imagine that chamber going wrong.
KBUM!
nice, amd puts more effort in gpu than in cpu ;D but as I read the vapor champer pros and cons, why do sapphire and such use this technology and didn't settle over to the liquid chamber tech, since that is nothing new in cooling terms.
yea lol, didnt think of that. if it will be upside down (which is the case if you look at your graphics cards), that technique would be totally negating the cooling effect since the liquid has no contact to the chip surface.
FinsUp!
Meh, ATI.
Anyways, i want to see how this performs compared to custom heatpipe solutions. Good for AMD's graphics. Always innovating.
what about if the card is upside down?, therefore the liquid would be on the other side and it would be trying to evaporate via air, sounds bad imo
Originally Posted by Abs.exe
AMD has failed with bulldozer, I hope they won't fail with their HD series.
EDIT: In title if you add "HD 7000 SERIES liquid cooling" there would be 300 pages by tomorrow.
Don't worry, the gpu side is something they are doing very well in.
Doesn't work like that. Orientation doesn't affect it.
Awesome. Now I just need a release date
There's definitely going to be a wick or something that holds liquid against the core side. Not factoring that into the cooling design would be very shortsighted on AMD's part and extremely unlikely. Like forgetting to build brakes into a car.
It looks good though, but I'm worried as to whether they did this to improve temperatures, or are the next series of cards going to just run hot in general.
Just because AMD acquired ATi and they're all the same name now doesn't mean they don't still have ATi video engineers and separate AMD cpu/chipset engineers... I really do not see how one has to do with the other. I still see them as separate entities although being labeled "AMD".
With that said, I'm interested to see more info on the new GPUs.
This is definitely interesting...
Originally Posted by Dmac73
Meh, ATI.
Meh... get with the times, it's AMD.
And this is different from the vapor-chamber coolers they use in the HD 6900-series and GTX 570/80 how?
Sure, it's more liquid, but as far as I can tell it's an evolution of the "heatsinks" used in today's graphics cards.
Uh, look at the picture? I don't know how you could have missed the rather obvious bullet points and illustration. It quite clearly shows the difference.
Yes, it's an evolution. According to the paper, it will be easier to manufacter (cheaper) and cool better.
What point are you trying to make?
so how are AMD cpu's able to cope with "THIS MUCH POWER" (if you don't get the reference you're totally out of the loop).
Any way niceeee, can't wait to get one
PC Evangelist
The idea is Eyefinity. At those resolutions BD will cope just fine and will be as fast as Intel because its all GPU work.
1 - 20 of 22 Posts
