1 - 5 of 5 Posts
I just started to use a double monitor setup with Extended desktop feature. But there is no point if i can't interact both monitors at the same time. Whenever i use one of them the other one lose focus and any fullscreen aplication just goes alt+tab.
Also using win+d (show desktop) shows both desktops not the active one thus ruining other view plan.
I just want my setup to act like 2 different computers that i can use with one keyboard and mice. Something like "mousewithoutborders" where you can choose the focus of your input devices and control 2 different pc on lan.
Right now this setup only helps me to monitor temperatures at the second display.
PS:Using windows 7 if you need that.
Discussion Starter #2
Well ultramon was promising until right side of this post is shaking like hell. Not sure it is about ulramon but never happened before.
Do you have all the updates for win 7? It seems like updates broke and fixed an issue with duel screens.
Do you have a gpu? or just igpu?
Discussion Starter #4
I am not sure you understand me about this problem. Ultramon has an option "show the desktop on current monitor" which does what i want.
https://www.dropbox.com/s/zi74jxffuocsi5c/UltraMon_2018-06-02_20-59-43.png?dl=0
Now i don't think it is possible to not lose focus on a FULL SCREEN application when using the second monitor. But i am still trying my chance here.
Discussion Starter #5 (Edited)
To make myself simple i want full screen applications on both monitors
https://www.dropbox.com/s/xv17ofohq87gnb5/2018-06-02_21-15-52.png?dl=0
Right wow this works like this if i use left side (click anywhere) both of them stay like this. if i click right side (hearthstone side) left side goes down and hs got focus.
Edit:Hs responds to tooltips so as long as i dont click at hs i can use both applications full screen
1 - 5 of 5 Posts
