1 - 3 of 3 Posts
I really want this and I don't know if it exists. Rather than just having an external DVD drive and external card reader and external this and that, what if you had an external bay that you can put whatever you want in, that had three bays so it's like the 5.25" cage of your desktop, only external. Give it a USB 3.0 or eSATA connection (or two or three) and you can swap it between your desktop and laptop depending on what you need to do. I'd put in a DVD+/-RW burner, a BD-ROM drive, and card reader.
Does this exist?
If I recall; something like this did exist.
It was a DVD Drive, 32 in 1 Card Reader, 2 USB 2.0 ports, & eSATA.
Wither either 2 x USB ports plugged in or 2 USB & eSATA (you needed the eSATA plugged into to use the front eSATA of the panel.)
It was right when Netbooks started coming out. But it wasn't a 5.25" size. It was really thin. And designed to be on it's side.
You could probably make one though. And it wouldn't be that hard.
1 - 3 of 3 Posts
