"Extreme HAF Makeover"
OK, So I have dreamed of modding a case and making a work log for soooo long i figured i'd go ahead and try.
This is my first time so if i get anything wrong please give some advice or info so i might be able to right the mistakes i make/ing
Build List1) HAF 932 (Window and hinge mod)
2) Rampage III Extreme X58
3) I7 930 (lapped)
4) 6GB OCZ Platinum
5) H50 (Modded)
6) GTS X-FLOW
7) DangerDen Fillport/res
8) WD Raptor 300GB
9)Fan Controller??????
10)mdpc-x sleeves/heatshrinks (black/red)
11)fans (6 x coolermaster 40cfm 19db red) (4 black randoms) (HAF fans)
OK, So half the stuff arrived today and i sent the HAF of to the shop to get powder coated 2 day wait on that.
So i started with the H50 as i had all the parts handy.
I had no trouble removing the the tubes and cover etc straight forward thanks to the guys over at the H50 club thread for the guides
When it came time to testing however i ran into some problems.
I used an AMD board i had with my old 955 chip and set it up for testing.
After i switched it on, i could hear the pump working but couldnt see the flow :/ i think i might of put the bottom plate on wrong, i dont think so but i cant think of anything else right now
I'll be home again in about 3 hours so ill get the preliminary pictures up and hopefully have some feed back on the pump issue.
stay tuned
3) I7 930 (lapped)
4) 6GB OCZ Platinum
5) H50 (Modded)
6) GTS X-FLOW
8) WD Raptor 300GB
stay tuned
