[email protected] client troubble...
225 Views 8 Replies 4 Participants Last post by  Tufelhunden
I just installed Vista HP on my computer and I can't seem to get my CPU console client to work. It just will not let me type in my password. I can type my username but when it asks for the password I type it in, but the curser doesn't move. Something I am missing?
1 - 9 of 9 Posts
I think it's a security thing. Just type it in and make sure you get it right. At least that's what I remember but I could be wrong.
I type it in, but the curser dosn't move. It's like I am not even typing. It only happens on the password.
that's normal
just type it and press enter, it works just fine.
Originally Posted by boydyboyd
that's normal
You my friend get kudos. It worked great.
lol no problem
it confused the hell out of me the first time.
Im not sure what that's about but before it asks you to enter your username + password for your PC it says "Unable to remove previous install, install failed". My guess would be to remove every trace of the FAH CPU console client and start fresh.
Delete the ./fah folder and uninstall it from the program list. Then try re-installing it the method you have been doing.
But this is just a guess, so don't quote me on it
You have a windows password correct? You need to set on if not, prior to reinstalling, as the password it wants is your windows one.
1 - 9 of 9 Posts
