1 - 12 of 12 Posts
I installed the GPU [email protected] system tray client and to my surprise it work out of the box
I have wine version 1.3.2 and Ubuntu 10.04 64-bit nvidia drivers 256.53
I have recently removed all wine related files and programs and reinstalled wine do to sum errors I was getting with CSS
so this is on a clean install of wine
Originally Posted by 1337LutZ
Nice!
you should not use the viewer tough, since it decreases your PPD by 90%
viewer?
you mean the thing that shows the atoms?
I was just showing you guys that it works
Discussion Starter #5
Originally Posted by AvgWhiteGuy View Post
What kind of points are you seeing from it?
I got 800 ppd give or take with only my cpu
when I added my gpu I now get 2400 ppd
Not new to Overclock.net
Originally Posted by 3dfxvoodoo View Post
I got 800 ppd giver or take with only my cpu
are you not running folding 24/7? (that would explain why your ppd is lower than it could/should be)
Discussion Starter #7
almost 24/7
my cpu is folding 24/7 but my gpu is only folding at night
Ahh... I really need to get back onto Ubuntu and check this stuff out for GPU3. Shame I've got no hard drive space left.
Discussion Starter #10
I may get a 470 gtx sum time this winter
and I will check if GPU3 works when I get one.
Run a Live CD or boot from a USB stick. Perhaps a VM?
this
Discussion Starter #12
You could check it with your 260, it'll take a PPD hit though. 200 series and GPU3 don't play well together.
this is what I get when i try it
if any one has a fermi card please try GPU3 with wine
I'd like to know if it works
1 - 12 of 12 Posts
