1 - 20 of 30 Posts
My friend asked me to check out his PC, said the PSU is dead., i tested the PSU, it's fine. but there is no power getting to the M/B. Gigabyte GA-78LMT-USB3, seeing as the PSU works when using a shunt across the power/ground pins in the mobo connector i figured it must be the case/switch is the issue(?). so i am trying to figure out if the connectors on the F-Panel Header are configure properly. anyone any ideas?
edit: i can't read
double edit: here you go
power should be top row #3,4
Discussion Starter #4 (Edited)
thats what i was thinking., the 2 pairs of plugs are on the HD activity & Reset switch pins. (top left of block) , and the white/orange pair are in the bottom right corner, , there are actually three pins, only two wires in the plug. so i'm thinking if he has wired it up wrong, it could be very wrong, just trying to confirm for definite.
Discussion Starter #5 (Edited)
how can you tell which are the positive wires, and which are the negative ones. it seems like it should matter (?)
Discussion Starter #6
ok, bit of confusion there, i think i got it now
Discussion Starter #7
ok, so now we have pwr to the m/b. via the front case switch. but nothing to monitor.
Discussion Starter #9
it powers up. all fans running, just nothing getting to the monitor. i should at least get a bios screen, right ? maybe i need to clear the CMOS ?
Discussion Starter #11
i dont have a spare battery to hand. the monitor is connected to the Mobo, not the gpu.
The motherboard graphics disable themselves if there is a graphics card installed. You can't get output from the motherboard if there's a graphics card in one of the PCIe slots.
What I described in the previous paragraph is the default behavior of the BIOS. If you manually change certain settings in the BIOS menus, you can get the motherboard output to work while a graphics card is installed.
Discussion Starter #13
oh. never come across that before, thank you. ok, i have plugged the monitor into the gpu. still no post.
Discussion Starter #14
removed gpu. monitor now back to mobo. still no pictures.
Discussion Starter #16
no idea. staring gormlessly into the case. looks fine from here.
Discussion Starter #17 (Edited)
i can't see anywhere to plug in a pcie or cpu cables.
also no power to keyboard.
Post a picture of the side panel off, maybe we can see something that isn't plugged in.
Discussion Starter #20
pics
1 - 20 of 30 Posts
