Woot!!!!
Highly recommended to finish all work before updating!
Press the finish button at the top, so once you complete the work units you will not receive anymore then you can update the client.
Win 7 64bit - Direct Download
Other OS download link
Found bugs by me
Adding remote hosts
Fermi + Non Fermi Bug - Found a work around
Will add more as I catch them...
Change logs...
v7.1.22
Found bugs by me
Adding remote hosts
Change logs...
v7.1.22
v7.1.23Added proxy support with authentication types: none, basic & digest.
Added proxy configuration tab to FAHControl.
v7.1.24Fixed bug caused by ignoring WU return code after a quick pause/unpause.
Set default verbosity to 3.
Explictly white-list Fermi GPUs & downgrade if CUDA driver is insufficient.
Added new GTX 470, 485 and 590 to GPU white-list.
Moved FAHControl single app port within 0-65535 range. #604.
Filtered out 'Theater' from GPU list.
White-listed Nvidia Quadro G8x cards.
Move all ATI R700s GPUs to species 3 and R800s to species 4.
Don't allow passwordless access even if password is not set.
Don't automatically allow IPs in command-allow-no-pass.
Don't call battery status code if not necessary.
Release resources related to battery query in OSX. #593
Allow changing the number of CPU threads mid run but warn. #292
Fixed client new and client connection options saving. #617
Lock database on startup to stop multiple runs of FAHClient in same dir.
Pass '-service' option to core when running as a Win32 service. #592
Fix permissions for All Users Windows install. #595.
Don't download a new WU if max-units is reached. #607
Added GeForce GTX 460 SE to the white-list.
Fixed 'core-priority' in FAHControl.
Fixed options save.
Don't allow changing 'local' client name or IP.
Don't try to autostart the local client once online.
Fix permissions problem in RPM. #627
Hide 'Status' tab in novice mode.
Added project info. In novice mode only by default.
