1 - 7 of 7 Posts
Hello all,
After leaving folding for some time I am finally able to contribute again. Im using my servers I3 2100 to fold. Im having a problem getting Fahmon to work with FAH version 7. Fahmon is installed on my desktop and V7 is on the server. Fahmon wants to point to "fahlog.txt" but v7 is creating "log.txt" What am I doing wrong. Im currently running [email protected] V 6.34 just so it plays nice together with fahmon.
Any suggestions?
Thanks!
· Premium Member
I've never used fahmon, so I had to download it, and check it out. It looks like it hasn't been updated in a while, and doesn't have support for v7.
I would suggest using HFM.net to monitor your progress. You can download it here: https://code.google.com/p/hfm-net/
Once you have it installed, it's pretty easy to get a v7 client added. There is a 'Client' Menu, then you go to 'Add Client (v7)', then you put in the IP of the workstation, and the password if you have one configured in v7.
It should work straight out of the box if you're installing it on the same workstation that is running the v7 client.
You don't have to though, if you want HFM.net running on another PC in your network, you will have to edit your v7 config to allow those other PCs on the network access.
· Premium Member
HFM seems to be the new standard in FAH monitor. FAHMon used to be the standard years ago.
Just remembered.... V7 no longer supports reading the log file directly and instead requires getting info from the log via telnet messages. FAHControl and HFM both work this way.
Thanks for the help.
So Ive installed HFM on my desktop and V7 on the server. But im still having trouble getting the server to show up in HFM. Ive added my desktop(the monitoring system) ip into the config ip access field. So it now looks like this in the allow field:
127.0.0.1 192.168.1.199
What did I do wrong?
· Premium Member
After you made the change, did you restart the client? Changes don't take effect until you completely stop the client, and restart it. Because that sounds correct.
I typically make any changes needed in the config.xml file, I just find it easier. I'll put in an IP range too, I have DHCP on on my router, so it ends up looking like this:
<command-allow v="127.0.0.1 192.168.1.100-192.168.1.200"/>
<command-allow-no-pass v="127.0.0.1 192.168.1.100-192.168.1.200"/>
<command-port v="36330"/>
1 - 7 of 7 Posts
