Fahmon doesn't recognize the client?
284 Views 4 Replies 4 Participants Last post by  MR_Plow
I'm trying to fold off my 4870 and Fahmon has said N/A for over a day.
I'm 98% sure i sent it to the right place to look...
could there be an issue because i'm running 64 bit?
sorry if this is a previously/frequently asked question
1 - 5 of 5 Posts
if it says n/a you probably selected the wrong directory. It shouldn't have anything to do with the OS.
Here is the directory you are looking for. Input login/name for USERNAME.
C:\\Users\\USERNAME\\AppData\\Roaming\\[email protected] e-gpu\\
It was different to set up for win7 then it was for xp. (Most guides are for xp)
Ill BRB
Edit: Blue's got it ^^
ah yup thanks guys
(was using the "program file" instead
1 - 5 of 5 Posts
