1 - 16 of 16 Posts
1. Right click the short cut to the client.
2. Open Properties.
3. Copy the "Start in minus the "
4. Open and Right click on the open white space in FahMon, copy the link and make up a "name" for the folding device
2. Open Properties.
ok what now?
Originally Posted by startekee View Post
First things first. Go into control panel then click classic view then folder options then select view hidden files and folders
done
Right click on the folding Icon in your system tray.
Go to 'Status' > 'log file'
It should say something like
C:\\Users\\Phil\\AppData\\Roaming\\[email protected]
Near the top.
Copy and paste that into the 'location' part. Enter a name and click ok. That is the GPU tracker set up
Originally Posted by silverbullet132 View Post
ok what now?
What now!
After that, open the FahMon and it should report the client(s) progress. It may not be accurate for the first day or so, it needs to get the PPD ballance.
So, is it working now?
Discussion Starter · #8 ·
What now!
your method didnt work, IcedEarth's did
thanks though
edit: is it possible to run the gpu client on a ati rage 128 all in wonder pci?
thanks
its up and running now
is 1803.13 ppd good for my card @ stock speeds? (777mhz core 1126mhz mem)
thats about right for an ati card on the GPU2 client. The ATI cards don't fold well with the GPU2 core. Seems to be orientated more towards nvidia.
thanks
I was getting 1.8K with my 3870 mate. Then I OC'ed it a tad, and it went to 2K
Seems about right to me
Your PPD doesn't stay constant, it shifts slight depending on what WU's you get. So don't worry if it doesn't constantly read 1.8K-2K although it should stay around there.
thanks though
The short cut or start up is the same thing as is the target.
(Is this all some Vist vs XP issue in the instructions?)
You need a 26xx or later ATI card to fold.
Discussion Starter · #12 ·
ah alright
i know its off topic but would someone please be able to locate windows xp drivers for the ati rage 128 all in wonder? display drivers proffered and if possible drivers for the tuner portion of the card would be amazing
ah alright
give this a try.
or the official ati site here
1 - 16 of 16 Posts
