1 - 20 of 76 Posts
Hi All
First PC I've built that's worth a build log. I will be turning a Borderlands 2 loot chest into a mini gaming rig for the wife as her 2 or 3rd xbox is drying. I have no set budget for the build but aiming to spend about £400 a month on it till its done. The work will mostly be done on my lunch breaks at work as more tools and I don't get a messy house.
[The Specs]
Processor: Intel Core i5 4440
Motherboard: MSI H87I Socket 1150 H55 Mini-ITX
RAM: Corsair 8GB DDR3 1600MHz Low Profile Vengeance Memory
GPU: EVGA GTX 750Ti Superclock 2GB
Storage : Seagate 600 Series 480GB + Seagate 2TB 2.5HDD
Case: Borderlands 2 Loot Chest
Power Supply:Silverstone Strider ST45SF-G
[Watercooling bits]
CPU Cooler: EK-Supremacy - Nickel
GPU Cooler: EK-VGA Supremacy - Nickel
Radiator: Alphacool NexXxoS ST30 120mm Single Radiator
Pump/Res: EK-DCP 2.2 X-RES (incl. pump)
Here is a photo of my Loot chest.
Here is the loot chest open to show the little space inside.
Few of the bits that have turned up today. I only started ordering bits on Friday
Subbed
Me gusta Borderlands.
Did you say Abe Lincoln?
very subbed
Any advice on watercooling will be appreciated I have never done it before and kinda being forced into it due to the case.
I have gone with EK block due to seeing them about and they look very nice that's about it.
Subbed Looks like it will turn out great
Discussion Starter · #13 ·
On this hour lunch I sanded down the the dvd slots area so not that's not sharp.
I have also cut the holes for the PSU power and exhaust fan.
They will be cleaned up tomorrow lunch and I will work out a mounting method.
Starting to get a real appreciation of the level of work that goes into good looking builds.
Discussion Starter · #14 ·
Few more bits have turned up.
Was hoping to spend this lunch mounting the radiator but I need to get some shorter screws the radiator came with screws for 25mm fans but I have 12mm fans didn't think to get any.
Covfefe
Subbed - I think you may need a bigger rad though for CPU & GPU, I'd recommend a 360 minimum.
Discussion Starter · #16 ·
The 750ti uses about 60watt Max also going with a low i5 to bring down the watt. I could fit a 240 to the bottom but would have no space for PSU and pump. So a 360 wouldn't even get close to fitting in.
Covfefe
Very interested to see what happens.
Discussion Starter · #18 ·
I will measure the case tomorrow so people have an idea of scale.
From the thinkgeek website they have this "Dimensions of Loot Chest: approx. 18" long x 8" deep x 6.25" tall" they are very much measured at the largest points and not the useable space I have.
1 - 20 of 76 Posts
