1 - 11 of 11 Posts
Started yesterday mourning, when I came home from work. Turn on my computer, and it wouldn't post. After hitting the reset switch a few times, it finally came on and was running fine all day. This mourning, I turned it on and again, fail to post. And after hitting the reset switch a few times, it came on. And now its running fine. I had something like this the problem before, and it turn out to be bad ram. If RAM is the problem this would be my 3th time since I built the computer that RAM has fail. Second time since I change power supplies early last year. Once its running, its running fine. Any ideas? Sadly, I do not have any spare parts to switch out or another computer to test parts on.
Specs Everything is at stock settings
Mobo: Asus M3N72-D 750a
CPU: Phenom x4 940
RAM: Patriot G-Series DDR2 4GB
HD: Western Digital Blue 500GB
PSU: Kingwin Lazer 850w
If its a major problem then I will just go just get the new build that I want.
try booting your mobo outside of the case and see if it works. If it does then chekc your case for anything grounding the board. Happened to me about 2 days ago.
Discussion Starter · #11 ·
Before I went to bed, last night, I turn it back on. It booted and posted without a problem. This mouring, I turned it on, started again. Slow post. Took about a minute to post. I clear cmos, and reseat my ram.
1 - 11 of 11 Posts
