1 - 11 of 11 Posts
That's a nice OC considering you are doing it with DDR2, might be a bit high voltage thou.
Yes CPU voltage,although it's up to 1.55 max according to AMD, you should try at 1.5 and 1.52 at most, it should be just as stable then but less heat.
My condolences, let it rest in silicon skies in peace.
Originally Posted by Undervolter View Post
Every motherboard that dies without killing the CPU, is a motherboard that dies with honour.
Did it come from planet Klingon ? They are high on dieing with honour.
1 - 11 of 11 Posts
